Open assembly having missing external references
milind.badgujar
Hello All,
I am trying to open a assembly file which was created using external references.Now those reference files are missing and while opening that file dialog box appears to select missing reference files.
I would like is there any config setting , setting which will allow me to suppress add missing reference dialog.
I believe you want this one:
fail_ref_copy_when_missing_orig no
You'll get a warning, but the copied geometry will remain in the last state when the external ref was present. It will not fix, however, missing assembly components. Those will have to be suppressed, deleted or found at retrieval.
LinkedIn
