I am using Creo Parametric Release 9.0 and Datecode9.0.1.0
I used to be able to open solidworks files from within creo. But now when I select "open" there are no solidworks options listed in the filetypes. And if I select "all files" the solidworks files still don't show up. How do I restore the ability to open solidworks files? I think this change happened when I switched from creo 8 to creo 9, but I'm not sure about this timing.
1.] run ptcstatus.bat to see what licenses are available
2.] open parametric.psf from Creo 8.0 installation in Notepad and investigate ENV=CREOPMA_FEATURE_NAME= line
3.] open parametric.psf from Creo 9.0 installation in Notepad and investigate ENV=CREOPMA_FEATURE_NAME= line
Thanks Martin!
I must have botched the install somehow. I reinstalled creo parametric and it once again works.
