Option to set radius value for the size of the break in dimension extensions lines
Jo_shi
3-Newcomer
I have found that sometimes the value is set, sometimes not. Where can I define the value? So far I could not find any configuration option.
gkoch
(To:Jo_shi)
Hello Joshua,
it seems the value of the DTL option wittness_line_offset is used by default.
Gunter
gkoch
(To:Jo_shi)
Hello Joshua,
Gunter
Jo_shi
3-Newcomer
(To:gkoch)
Yes that's right, but this option also defines the distance of all witness lines to the body edge. Unfortunately this distance according to DIN is defined 0.
