PTC Creo Parametric 3.0 M070 crashes
jdesai
hey i have recently downloaded creo 3.0 college/university edition.. done with licensing installed creo thrice but still when ever i try to open PTC Creo Parametric 3.0 M070 it get crashes or directly troubleshooting window pops up.
system specifications: windows 10 home single language
6 GB ram
intel core i5-320m cpu@2.50ghz
64bit operation system x64based processor
graphices card: NVIDIA GeForce GT 630m with 2GD dedicated VRAM
plz help me how to fix this problem
8 REPLIES 8
STEVEG
(To:jdesai)
Is it possible they have a newer build?  PTC's latest build they released is M100 but I don't know if they release the student version of the same build at the same time.
MartinHanak
(To:jdesai)
locate config.pro file in Creo installation, open it in Wordpad and add following option at the end. Then test Creo.
graphics win32_gdi
MH
Martin Hanák
CREOCapture.PNGTRIED BUT ITS SHOWING ME THIS ERROR
MartinHanak
(To:jdesai)
1.]
config.pro you edited is not the right one.
Please edit this file C:\Program Files\Creo 3.0\M070\Common Files\text\config.pro
2.]
Access denied error message means that you do not have Administrator rights and therefore you cannot save the file.
Suggestion:
> launch Wordpad as Administrator
> open C:\Program Files\Creo 3.0\M070\Common Files\text\config.pro
> edit config.pro and save it
MH
Martin Hanák
STEVEG
(To:jdesai)
Or even try starting Creo with any config.pro.  It might be related to something in there.
STEVEG
(To:STEVEG)
I meant try starting Creo without any config.pro
BenLoosli
(To:jdesai)
What is your Start in Folder set to in the shortcut?
Is the config.pro file or folder set to read-only?
Mahesh_Sharma
22-Sapphire I
(To:jdesai)
OR you can add -g:win32_gdi in shortcut of Creo as:
Select Creo Shortcut > Right Click > Properties > Place cursor in target > Move cursor to end > Add a space followed by -g:win32_gdi. (e.g. "C:\Program files\Creo 3.0\Parametric\bin\parametric.exe" -g:win32_gdi)
