hey i have recently downloaded creo 3.0 college/university edition.. done with licensing installed creo thrice but still when ever i try to open PTC Creo Parametric 3.0 M070 it get crashes or directly troubleshooting window pops up.
system specifications: windows 10 home single language
6 GB ram
intel core i5-320m cpu@2.50ghz
64bit operation system x64based processor
graphices card: NVIDIA GeForce GT 630m with 2GD dedicated VRAM
plz help me how to fix this problem
Is it possible they have a newer build? PTC's latest build they released is M100 but I don't know if they release the student version of the same build at the same time.
locate config.pro file in Creo installation, open it in Wordpad and add following option at the end. Then test Creo.
graphics win32_gdi
MH
TRIED BUT ITS SHOWING ME THIS ERROR
1.]
config.pro you edited is not the right one.
Please edit this file C:\Program Files\Creo 3.0\M070\Common Files\text\config.pro
2.]
Access denied error message means that you do not have Administrator rights and therefore you cannot save the file.
Suggestion:
> launch Wordpad as Administrator
> open C:\Program Files\Creo 3.0\M070\Common Files\text\config.pro
> edit config.pro and save it
MH
Or even try starting Creo with any config.pro. It might be related to something in there.
I meant try starting Creo without any config.pro
What is your Start in Folder set to in the shortcut?
Is the config.pro file or folder set to read-only?
OR you can add -g:win32_gdi in shortcut of Creo as:
Select Creo Shortcut > Right Click > Properties > Place cursor in target > Move cursor to end > Add a space followed by -g:win32_gdi. (e.g. "C:\Program files\Creo 3.0\Parametric\bin\parametric.exe" -g:win32_gdi)
