PTC_common_name, file rename
ptc-984704
Issue 1: In WF2, when I "save as" a .prt and .drw and then open up the new files for editing, the "PTC_common_name" parameter stays as the old part number instead of the new one. How do I fix this to show the new number? Issue 2: When I rename a .drw and .prt from "file > rename", it works but it also leaves the old part number in the directory as well. How do I get ProE to remove the old files automatically? We have another user here that does not have these issues on his machine. I copied his config.pro file and replaced mine with his to see what would happen and nothing changed. thanks Mark
Anyone have any ideas or comments on this issue?
