PTC creo with M1 chip :(
경오_10552987
Hi my  Macbook M1 Windows 11 ARM Ptc creo 7.0 when installed,  Creo will not run - nothing happes.
i'm sure win11 in my desktop runnung creo7.0 and 8.0. but  not my mac m1 chip.
7 REPLIES 7
Macbook M1 processor is not supported hardware platform. You have to use Intel/AMD processor.
Martin Hanák
ctraining
(To:MartinHanak)
I have successfully installed Creo 3 M190 X32 on my MacBook Pro M1. All modules work perfectly, rather its up and running faster than my other Windows 10 Laptop. Problem is X64 versions of Creo. Unfortunately Creo 3 is the last version that is available in 32bit.
Cool!  Did you run it in Parallels or something else?
Parallel Desktop
IanFT
(To:ctraining)
have you tried installing/running newer versions of Creo?
Ian
Mat
(To:경오_10552987)
According to a post on "parallels forum", You have to add
ENV=PROCESSOR_ARCHITECTURE=AMD64
ENV=PRO_MACHINE_TYPE=x86e_win64
to Your parametric.psf
Source: https://forum.parallels.com/threads/ptc-creo-wont-run.355699/
It seems, that otherwise Creo Parametric does not know what to do with an "M1" processor. Using the AMD64 binaries, lets Windows kick in its x64 emulation.
