Part Detail Options
ptc-2094888
7-Bedrock
Part Detail Options
I'm trying to understand the working files behind the scenes of Creo 1.0. I understand the config.pro, however there are detail options available for the .prt files. If you go to File > Prepare > Model Properties > Detail Options and click on change, a file comes up similar to what the config.pro looks like, however none of the settings in this file referece back to the options that I have set up in my config.pro. Where is it pulling this information from?
Actually, I believe it's pulling that information from a .dtl file, which is referenced in the config.pro.
I didn't know about the 'System Information' option in the help menu, not sure it'll help me with this issue, but thanks for pointing it out.
KrisR
(To:ptc-2094888)
Can you go to Help-> System Information and look through there to see where it's pulling from?
Kevin
(To:ptc-2094888)
These are the settings you would find in an *.dtl for drawings. I can't say for sure that it's the same for all installations but the default location should be in your Creo 1.0 install directory. Under that I think the settings are pulled from the Common Files\M030\text directory (reflects what is on my system could be different for yours).
KrisR
(To:Kevin)
Or do a system wide search for *.dtl.
