"Walter Pipp" wrote:
I have several parts created in Solid Works and translated in Solid Works to ProE. I need to create details of these parts but for some reason they jump from the original english units as created in Solid Works to metric. When I try to change the units I have problems. When I select make 1" equal 25.4 mm the part disappears and I see an message that says Regeneration completed successfully, but the part disappears When I open the file I get this error message. Could not read from Model Tree config file ..\tree.cfg. Can you help me?
