Am I right in the assumption that Pro/Photorender is different from Advanced Rendering Extension? Our license says we have Advanced Rendering, but the module screen only shows Pro/Photorender.
Dorian Ferrari
Mattel Inc.
Answer summary. Thanks all for the replies. This helped a lot for our IT staff.
You are correct. Your Advanced Rendering Extension must be added as a floating module, or you must configure your .PSF files to launch it with ProE.
Mike
Dorian,
ProPhotorender is certainly different to the Advanced Rendering Extension. The Advanced Rendering Extension will give you Photolux.
Firstly I would suggest checking that the ARX license has been obtained (maybe it is a floating option or something).
Secondly open up the Rendering Setup Dialog and check the renderer option. This should say Photolux not Photorender.
Hope this helps
Paul
