The toggle checkbox for Shaded Tool during play path only blanks tool when selected (checked). Unchecked tool displays wireframe. Model display style environment is set to Shading.
Is this a known bug? Display settings or config issue?
Creo 3.0 M050
Hello Eric,
The option is only valid for shaded modes (with/without edges...) and allows to toggle tool to display wireframe (for better visibility of geometry below).
When using one of the wireframe modes (including hidden, and no hidden), the option View > Shaded Tool should always be unchecked and not allow to be changed.
If it's different in Creo Parametric 3.0 M050, it should be reported to TS.
Gunter
