Community,
Please read the below snippet. No how many times I restart Creo 6, I always get this port conflict warning. Is there a way to resolve this? This happened during a PTC technical support call where I requested that I do not want to use LMTools to create services. I am using a locked license for Creo Parametric, and flex admin for Creo Simulate. Also, it takes an extremely long time to start Creo. Thanks in advance.
I resolved this by installing a newer version of creo.
Try the options listed in below article, it may help.
Thanks. I will look into it.
