I have simple question...
Does any of you have experience with printing from Creo Parametric to KONICA MINOLTA KIP 7580 MFP ?
Specification available in https://kipnews.kip.com/_Public/KIP75Series/KIP75SeriesSpecs.pdf
Description of my problem when printing via MS Printer Manager:
Thanks in advance for any piece information concerning printing on KONICA MINOLTA devices.
According to information from customer site the problem was resolved by installation of following drivers.
Windows Driver V4
Compatible with: Windows 10 64 Bit, Windows 11, Windows Server 2016 64 Bit, Windows Server 2019 64 Bit, Windows Server 2022
This new generation of Windows printer driver is based on the latest software technology and structure of Microsoft operating systems & applications.
(Requires KIP System K software)
Version #22.107.1532.0 (CERTIFIED) Release Date: January 21, 2022
https://www.kip.com/download-apps-details.php
INFO:
The problem is cause by decimal symbol set in Windows environment.
If decimal symbol = comma then print fails.
FYI ... INFO I post today is not solution. I do not understand why you set it as solution when you are not owner of this discussion.
Windows Driver V4
