Try playing around with the settings in the plot config dialog, and when you get things the way you want them (ie, with a successful output), hit the save button. Save the .pcf file as whatever name you want, then make sure it goes somewhere you can find it. Then, set pro_plot_config_dir in your config,pro to point to the folder where you are saving these .pcf files. They SHOULD show up in your printer menu next time. Personally, to avoid duplication I added mine to the folder that holds the PTC defaults. (in my case C:\PTC\proewildfire 4.0\text\plot_config) Hope this helps. c
Chris Benner
Autodesk ® Expert Elite
