When I open a drawing in Creo View and want to print, I can send it to our plotter printer fine, just not to our networked office printer which is a HP Laserjet P3011. I tried uninstalling and reinstalling drivers and installing via ip address to no avail. It is specific to this one workstation. Any suggestions?
What printer type are you selecting in Creo? You should be able to use the built in Windows print dialog and then select that specific printer. Things get much more tricky if you're trying to use one of the Creo built in plotter types.
