Anyone know where to look and what to do or not do to solve the
following problem :
When doing a Pro/E batch conversion from a drawing to a DXF file it
sometimes gives me different output as when I do it manually from Pro/E.
One of the issue I'm seeing relates to the B.O.M.
The B.O.M. is made with pro/report some lines are filtered, indices are
fixed.
Manaul created DXF is exact copy of the DRW
batch created DXF : filtered lines are back, fixed indices are all
messed up, instances are listed as "instance<generic>" instead of only
their instance-name
WF2 M180
