Using WF4, ProBatch Log is attached
ProBatch settings:
plotter: postscript
filename: *.plt (create single file)
plotter command: print /d:\\PrinterName
(4) Files in List
1000.drw
1001.drw
1002.drw
1004.drw
Problems:
1) Printer output is (4) copies of file 1004 (instead of one of each)
When I set the filename to *.plt with append file, I get (4) sets of all drawings in list. ie (4) copies of each!
2) drawings do not have any formats
How do I tell ProBatch to invoke a mapekey that sets up the search paths (/client) in the "ProEngineer command box"? (Lower RH corner)
Also, in the log file I noticed that the 1st object (1000) result is failure! Hmmmm?
Thanks for the help!
