Pro Borrow Issue
dmeschberger
Pro Borrow Issue
I'm pretty new to the Admin side of Pro-E, and we've reloaded all machines with 5.0 64-bit. For some reason, the Pro-Borrow does not work when you go off network and try to open Pro-E....it gives you the license server not available and shuts it down. When you use the Pro-Borrow it acts like it's doing it and when you check ptcstatus, it shows the license borrowed in the listing.....but again it's not working when you disconnect from the network.
I've attached the pro-e_borrow bat file for reference....to see if there's something missing or mis-typed.
0 REPLIES 0
