Pro/E 4
ptc-2882062
Pro/E 4
I just installed Pro/E Wildfire 4 Student Edition on my computer (running windows vista). When i first installed, it only showed a black screen, and I couldn't see anything. I updated my graphics card driver, and the program seemed to be working, except for the fact that it wouldn't save. Now, I can't open a file, save a file, confirm a change or really do anything without crashing. I've uninstalled and reinstalled three times now. I've tried everything I can find, but nothing works. I have no idea what else to do to make it work....
I think 64 bit Vista is required. Is that what you're running?
I believe there is a 64 bit version, but I have the 32 bit version. I have all of the correct specifications on my computer. Plenty of RAM, disk space etc...
I have never used a student version so only I can assume that you have hardware problem, possibly memory (most likely) or graphics card. Try installing it in another computer. What datecode do you have? See if you can get the latest datecode release. Pro/E runs in both 32-bit/64-bit Vista.
I'm having the same problem. Did you ever get Pro/E working again?
Are you blonde by chance? . . . . . . . . Kidding!
