Pro/E PDM server name location
pwyndham
When you have the config.pro option set to remember the server, where does it keep that information? I need to update some installers to point to the new server instead of the one I had when I created them.
I am thinking this would be some text file, or I am hoping it is.
7 REPLIES 7
I think, it's stored in following file:
C:\Documents and Settings\<Username>\Application Data\PTC\ProENGINEER\Wildfire\.wf\.Settings\config.fld
Best regards, Domenic
Domenic,
Yep, that is where it is. Well, on a Windows 7 machine it is here: C:\Users\%username%\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settings
Thanks for the info.
Paul
Paul,
The information is in a file named "config.fld" stored into the cache folder. (witch is defined by environment variable)
Personnaly, in the ProE startup script I copy this .fld file so I make sure users are connected to the right server.
Marc
Hey Marc-Andre,
Thanks for the reply to. I wanted to add this file to my launch application, what is the environment variable you set for the cache folder? I don't really want to have to program in that long app_data location and hope it does not change in Windows somehow.
Paul
pwyndham
(To:pwyndham)
I think I found it: PTC_WF_ROOT. Set it to the drive location you want Pro/E to use as the cache location. I am thinking c:\users\%username%\ProE\Cache.
I wish environment variables properly used the %username% variable. Maybe I just am doing it wrong.
There's 2 variables: PTC_WLD_ROOT and PTC_WF_ROOT.
Set it wherever you want.
I set it both under c:\ptc\localcache.
Ok, I finally got around to working on this some more.
I had a folder c:\Trial_Files created - obviously to store the WF5 trial files in. So, I thought that would be a good location to store the localcache as well.
Turns out the PTC_WF_ROOT is the only one that WF5 looks at. If I set up the PTC_WLD_ROOT by itself it reverts back to the app data location.
Then, I found that WF5 creates a subfolder called .Settings. The config.fld file has to be put in there or it won't be read.
Thanks for the help and pointers. I think I have it all setup now.
Paul
