Pro/E exits prematurely, when I open #Result window... #Format;#Result window. The analysis is shown like the settings during result window definition. I can edit and format the legend values, show and delete cutting and capping surfs and other graphic issues. Only formatting the result window Pro/E exits. Is this a known issue? Is it caused from my Logitech mouse (Mx510) ? The wheel is off sometimes, it feels like Pro is responsible for this too... Is it caused from my Athlon (XP3200+)? Are there settings for Internet Explorer necessary (Active X, Scripting, Java)?
... Analysis completed successful. The post processing works in independent mode. But I want to use the integrated mode for better graphics, saved view list etc (lots of different versions to compare...)
