Pro/E suddenly stopped working
dgschaefer
A co-worker suddenly can no longer launch either Pro/E WF3 or WF4.  It
was working fine Friday AM, now the splash screen pops up but Pro/E will
not launch.
I've removed all config files from his installation and double clicked
proe.exe in both WF3 & WF4 to remove all of our launch batch files and
the problem persists.
It generates a std.out file with one line - Exception - code was
-1073741819.
He has a less than 1 year old Dell workstation laptop with an M 620 i7
CPU running Windows XP Pro 32 bit SP3 with an Nvidia Quadro FX 1800M
graphics card running driver 189.21.  The machine originally shipped
with Windows 7, but was downgraded by our IT guy to XP.
Any ideas?
Doug Schaefer
LinkedIn
Update:
Tried a config.pro with these two options only:
web_browser_homepage about:blank
windows_browser_type ie_in_sep_process
Didn't help (and WF3 didn't recognize the second one).
IT is checking for viruses now.
Doug Schaefer
LinkedIn
Hello Doug
You could try to rename the .wf folder and try to start ProE again.
Regards
Daniel Garcia
>will
>not launch.
>-1073741819.
>Any ideas?
>Doug Schaefer
>Confidentiality Notice
>This is a transmission from Design Central Inc, Columbus, Ohio which
>may
>be privileged and confidential, and thus is protected from disclosure.
>This message is NOT intended for transmission to, or receipt by, anyone
>other than the named addressee (or a person authorized to receive and
>deliver it to the named addressee). If the reader of this message is
>not
>the intended recipient, or an employee or agent responsible for
>delivering this message to the intended recipient, you are hereby
>notified that any dissemination, distribution or copying of this
>communication is strictly prohibited. If you have received this e-mail
>message in error, kindly accept our apology and please delete it from
>your system without copying or forwarding it, and notify the sender of
>the error by reply e-mail or by calling  (collect).
