Pro/ENGINEER Installation Directory
nhanratty
Hi everybody
Many years ago as an applcation engineer for PTC I was advised that youshould not install Pro/ENGINEER into the Program Fles folder on a PC - the reason being Pro/ENGINEER did not like the space between Program and Files in the folder title. Consequently every Pro/ENGINEER installation I have ever carried out has always been into a folder like
C:\PTC\proewildfire3
I'm just curious to know ifis this still relevant advice. Does Pro/ENGINEER still get upset by the space? Did it ever get upset by the space?
Neal
11 REPLIES 11
As I recall this was only relevant for the old installations back on the
Sun sparc and Silicon Graphics UNIX based boxes and such. The space and
special characters no longer seem to matter.
Since WF 2.0 (and we are up to WF 4.0 now) we have loaded ours in a folder
that is named like this
C:\Program Files (x86)\proeWildfire 4.0
No issues, no problems
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
cell: (216) 990-8711
fax: (440) 266-2311
www.parker.com
Neal Hanratty <->
06/28/2010 07:13 PM
Please respond to
Neal Hanratty <->
To
cc
Subject
[proecad] - Pro/ENGINEER Installation Directory
Hi everybody
I'm just curious to know if is this still relevant advice. Does
space?
Neal
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailling list Manage your subscription
Use of this email content is governed by the terms of service at:
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
Yes, it is still relevant to stay away from spaces and special characters (such as punctuation.Although PTC claims that they meet Microsoft requirements for such, it is not 100%. Every few months, someone posts a problem related to this. We had one less than a month ago in which it was found that Windchill could not properly deal with the java path if it contained special characters.
Gerry
From what I have been able to tell for working with 2001, WF3, WF4, and WF5, the problem with spaces in the folder path is no long an issue for Pro/ENGINEER. Other PTC products (Intralink, Windchill, etc) still have problems on occasion and if they link up with Pro/E, then you may see that some options do not work.
The one example I can think of right now is if you have Pro/E installed to a directory with a space in it (ie, c:\ptc\wildfire 4.0\), then Intralink 3.4 will be unable to run the Import/Export command.
In Reply to Neal Hanratty:
Hi everybody
Neal
It's been the default location for Pro|E for many revs, at least back to
WF1, maybe 2001. We've used the default path offered (into the Program
Files folder) since then and have had no issues.
There are areas where Pro|E continues to choke with spaces in the path
or file name, but this doesn't seem to be one of them.
Doug Schaefer
LinkedIn
The standard install from the PTC disc will use spaces. Out of habit, I don't use them because the underlining code in PTC has Unix traits or at least I have seen enough issues that I believe it does.
I install under \ptc\wf4-m110
I like to indicate the build versions because I run Pro/E installation on a server and not the users computer. This allows for easy upgrades and downgrades as needed. 🙂
All
Just a summary of the replies I got regarding my query on installation
folder for Pro/ENGINEER.
Thanks to everyone that responded...some interesting viewpoints.
I think I'll stick to the PTC folder...
Regards
Neal,
We started with Unix before moving to Windows and I too was told spaces
were bad. Now, with several years of installs in the Program Files
directory and no issues I don't believe it really matters anymore
Mike Brattoli
folder that is named like this
Bob Frindt
Hi Neal,
I'm still doing it on any install that I do. Although, I have my Start
In directory in 'Documents and Settings' pulling my config files with
spaces and such with no issues. I'm pretty sure that retrieving model
files from folders with spaces is still a no-no.
Best Regards,
Matt Larsen
Yes, this is a good advice even today, though the implications of not
following it are much less severe today than they were in the past.
If you use Pro/Toolkit, it really dislikes Pro/Engineer installed in a
folder with a space in its name.
If you keep your libraries with ProE and happen to use a search path
file, every line with a space in it will not be searched.
Pointing Config.pro options to a library with a space in its name might
not work either.
It is still the best to define your own installation directory without a
space in its name.
All the best
Uriel Avron
We have put 3 and 4 in program files folder without any problems. No
problems with pulse either.
Best regards
Stephen White
Lawrence Srutkowski
Gerry Champoux
I think, it quit being an issue after WF was released, it might have
been a little after that, because we didn't go to WF immediately but
picked up on it with a later build.
Brian S. Lynn
Doug Schaefer
Damian Castillo
Neal Hanratty
Hello All,
A related issue that was touched on by some responders was the location of
the Pro/E model files and their paths.
Length of path may become an issue with backups of the various model files
if you choose to put them in Documents and Settings\My Documents\Guy with
very long name\etc\etc\etc folder. The issue is that a hard disk drive can
manage a longer path than many removable medias such as tape, CD ROM, maybe
DVD, etc. The models will work fine on your computer and you think you have
a good backup, however when you need to restore a backup you find that the
long paths have resulting in the backup software truncating names and
created a referencing issue making it very hard to get the files back into
the correct location. For this reason our project setup method locates
Pro/E project directories on shorter paths (not using interlink, etc.), not
in "Documents and Settings".
Everybody claims that they back up onto removable media, even if they don't.
If you have a contractor or collaborator who claims to be backing up, one
way to confirm is to look at the length of their paths. If any paths are
over 128 characters you may want to check further and confirm that the
backups can actually restore correctly.
Pat Harris
Principal Engineer
Product Design, Inc.
5133 Washington St., Suite 9
Downers Grove, IL 60515
lwh
(To:nhanratty)
Even if it seems to work most of the time, using spaces or special characters may have unexpected side effects.
Using ä (a-umlaut) in a workspace name f.i. kept ProE from loading drawing formats...
Just got through with an install of WF4.0 with Intralink 3.4 (M062). Space in the folder name for the install of WF4.0 ... By PTC install CD default caused me grief!! Linked session of Pro-E and Ilink kept giving "loadinpro" error and loss of viewed data in the workspace window. The initial setup install for WF4.0 created a folder named "proeWildfire 4.0" the fix was to have it install to "proeWildfire_4.0" or rename theexisting folder and re-run setup. That fixed the problem.
Dave
Hi everybody
Neal
davehaigh
(To:nhanratty)
That would be a problem specific to Intralink 3.x.
PDMLink/Intralink 8+ doesn't have an issue with the spaces in the ProE Install dir. I use "proeWildfire 4.0" all the time with no problems, although I don't typically install in C:\Program Files, which is the default. But I have even done that on a laptop with no problems.
David Haigh
