Pro/Engineer Wfire 5 for 64bit is not working proper
DiVenti
I have Dell Laptop Studio XPS core 2Duo 2.66 MHz 64bit, RAM 4 GB, VG Cards 1GB dedicated. But Pro/Engineer Wf5 with windows 7, 64bit is working very slowly.
I'm running WF5 M020 on Windows7/64 bit, everything seems to be fine. _____________________________ Luke DiVenti Wildfire5-M020/No Intralink/Win7-64bit Dell Precision T5500 Intel Xeon 3.2GHz/6GbRAM NvidiaQuadroFX3800
I had faced the same problem on both 32 and 64 bits of win7 but I don't have any difficulty while with vista on same machine ( Dell Optiplex 755 with total on board avail graphic memory 384MB).I would like to switch to win7 again if WF5 can run as is on other OSs.Would someone from PTC like to comment on the issue? Thanks in advance
This document was generated from the following discussion: Pro/Engineer Wfire 5 for 64bit is not working proper
1 REPLY 1
DanMarotta
(To:DiVenti)
Luke,
PlanetPTC Community is not staffed with technical support represenatives. I suggest logging a case, http://www.ptc.com/support/index.htm
-Dan
