I am using the function ProAsmSkeletonCreate to add skeletonparts in an ASM.
This works fine for adding the first one, but the second time Pro/E prompts the User to specify the Construction Constraints.
For the Template Parameter of the Function i am using the template part, if I use NULL the Function works and places the part on the DEFAULT position.
Does anybody know why this happens, is there a way to create further skeletons unplaced, like the checkbox shown in the GUI during manual placement via Pro/E?
So that I can set the Constraints via Toolkit.
Or is there a config option that I have to set to the right value?
Dominik
Dominik,
Try set config.pro option multiple_skeletons_allowed to yes.
You can only set constraints for sencod or later skeletion.
Gary
In Reply to Dominik Hartinger:
Dominik
