"Julian Kluge" wrote:
already tried to change the OS to all possible version of windows but it doesn't work.
"Luca Nicoli" wrote:
I have the same Laptop and I finally got it to run. If it is the same problem I ran into, it's not the Laptop. Take a look at the License file. I found that when PTC sent me the new license file for WF5.0, the file was missing two line items. The line items are directly below the "START: License File for HOST ID (MAC ADDRESS). The lines contain the information about the SERVER_HOSTNAME... and DAEMON ptc_d __PTCD_PATH__. You can get the full text info from your old license file and paste directly to the new one. See if that works. If not, I would call Tech Support. Good luck.
