ProE without PDMLink
EricHuffman
2-Explorer
Gurus,
I am using Wildfire4 with PDMLink9 most of the time. The other time I am
supporting a customer who is still on Wildfire3 with no PDM. Every time
I launch W3 it wants to register the server; is there is a config.pro
option that I can add to my wildfire3 config so it will quite asking me
to register the PDMLink server?
Eric
Look in config.pro for 'DM" options and comment them out.
Try:
dm_remember_server no
Eric,
I haven't use the config.pro option Gerald was talking about, but you could make a separate batch file to launch your different Pro/E configurations. Within the batch file, before you launch Pro/E, include the command "SET PTC_WF_ROOT=<absolute path=" where=" you=" want=" to=" cache=" your=" windchill=" session=">". I believe that the server information is stored in the cache defined by the "SET PTC_WF_ROOT" environment variable. So then you'd have a short cut to launch WF4 w/ PDMLink server and one for WF3 w/o PDMLink server (since you won't register one).
Willy Chung
