Dear readers,
I use Creo 3.0 student version. I try to do a simple simulation using thermal mode (To see the temperature distribution along a block). This mode does not active in my software, a message shows this:Unable to get required Creo simulate license. The same Problem appears if I use Creo Parametric, Please see the attached photo.
Kindly, is there anyway to do my simulation?
Hi Toby Metcalf
Looks like a Creo simulate question, could you move it to Creo?
