Is there a specific setting within the recipe file that indicates that the .asm and the .prt files be published? Our .drw are being published just fine, but as of last week, no assemblies or parts are publishing. Any ideas? Evidently something has been changed on the cad worker, but I can't determine what. I reset the recipe and config to it's original state, but it still doesn't fix it. The error seems to be on the cad worker - here is the detail from the Publish Monitor:
Jul 7, 2010 9:46:15 AM:Start PublishJob: Assembly-01-4707-78.asm,A.1
Jul 7, 2010 9:46:15 AM:"As Stored" Config Spec is available
Jul 7, 2010 9:46:15 AM:The EPMDocument As Stored Config Spec was selected as the default
Jul 7, 2010 9:46:15 AM:make temp dir F:\ptc\WC9.1\Windchill\temp\pubtemp\publish11058.tmp
Jul 7, 2010 9:46:15 AM:Start: Assembly-01-4707-78.asm,A.1
Jul 7, 2010 9:46:15 AM:Authoring Application: Pro/ENGINEER
Jul 7, 2010 9:46:15 AM:empty temp dir: F:\ptc\WC9.1\Windchill\temp\pubtemp\publish11058.tmp
Jul 7, 2010 9:46:15 AM:Transferring Files to: F:\ptc\WC9.1\Windchill\temp\pubtemp\publish11058.tmp
Jul 7, 2010 9:46:15 AM:Number of Files (identified to be) Transferred: 14
Jul 7, 2010 9:46:15 AM:ProE Asm Conversion
Jul 7, 2010 9:46:15 AM:Added request to PROE queue
Jul 7, 2010 9:46:16 AM:Job 14 submitted to worker: macadworker-PROE:1
Jul 7, 2010 9:46:16 AM:LOGID: worker_2228.log
Jul 7, 2010 9:46:16 AM: Registering Server
Jul 7, 2010 9:46:18 AM: Downloading 01-4707-78.asm
Jul 7, 2010 9:46:20 AM: Loading 01-4707-78.asm
Jul 7, 2010 9:46:21 AM: Processing 01-4707-78.asm
Jul 7, 2010 9:46:21 AM: Processing ~.prt
Jul 7, 2010 9:46:22 AM: Processing ~.prt
Jul 7, 2010 9:46:22 AM: Processing ~.asm
Jul 7, 2010 9:46:23 AM: Processing ~.prt
Jul 7, 2010 9:46:23 AM: Converting Author States
Jul 7, 2010 9:46:24 AM:Helper: Connection to worker has been closed. Shutting down...
Jul 7, 2010 9:46:24 AM:Asm Processing Returned: $ERROR$ Helper: Connection to worker has been closed. Shutting down...
Jul 7, 2010 9:46:24 AM:CadAgent Returned: $ERROR$ Helper: Connection to worker has been closed. Shutting down...
Jul 7, 2010 9:46:24 AM:End (with Error): Assembly-01-4707-78.asm,A.1
Jul 7, 2010 9:46:24 AM:remove temp dir: F:\ptc\WC9.1\Windchill\temp\pubtemp\publish11058.tmp
Jul 7, 2010 9:46:24 AM:Publish Complete event dispatched
Jul 7, 2010 9:46:24 AM:End PublishJob (with Error): Assembly-01-4707-78.asm,A.1
Hi Joanna,
Please check if following works:-
1) Open the recipe file "proe2pv.rcp" found in CAD worker installation folder.
2) On Basic tab un-check the option "Output Author States"
3) Stop the CAD Worker from CAD /Worker Agent Administrator UI. Reload and Start again.
4) Check the result of publishing with above settings.
Refer Attachment. I' ll be glad to know if that helps!
Vabs.
