Trying to understand how ProductView is being supported. Many years ago, I believe you need a separate server and source the objects in Windchill/PDMLinks so that users can view the ProE objects without using the actual proE license.
Can ProductView be loaded at the client's machine and be able to open up a ProE object directly from Windchill?
Hi, you dont need a Windchill system to use CreoView.
The CreoView application is installed localy and you can open files from any source.
