I am running DVCS 7.0 M100, Pro/ENGINEER Wildfire 4.0, Pro/INTRALINK 3.4 M060 on Windows Server 2003 Service Pack 2 (Enterprise Edition) and I have a problem configuring a proe worker.
Details:
I am using the ProductView Thin Client and I get the following error when I select an Intralink (Pro/E) part in the ProductView GUI to try to get ProductView to translate and view the part. It looks like a Proeworker needs to be configured but I can ‘t get that configuration to work. This is the error message I get:The ERROR MESSAGE AFTER I CLICK on link “Submit bearing_ball.prt to PROE for conversion”:4/3/2009 9:40:56 AM: Status report begins at: 4/3/2009 9:40:56 AM
4/3/2009 9:40:56 AM: Name: 000-00233-0_1.prt Branch: main Rev: - Ver: 2
4/3/2009 9:40:57 AM: Checking EDR for 000-00233-0_1.prt main|-|2{}
4/3/2009 9:40:57 AM: Copying out all dependent files...(As Stored)
4/3/2009 9:40:58 AM: *** Copy out files: Starttime = 4/3/2009 9:40:58 AM Totaltime = 0 s
4/3/2009 9:40:58 AM: Checking Object Type...
4/3/2009 9:40:59 AM: Result: STANDARD 000-00233-0_1.prt
4/3/2009 9:40:59 AM: Submitting Part to ProE worker...
4/3/2009 9:41:00 AM: *** ProE conversion: Starttime = 4/3/2009 9:40:59 AM Totaltime = 1 s
4/3/2009 9:41:00 AM: Error: CadAdapter.ConvertCadFile failed Error: PROE conversion rejected, no LOCAL Worker available.
4/3/2009 9:41:00 AM: Status report ends at 4/3/2009 9:41:00 AM I did run the proe2pv_config and provided the correct settings and so a proeworker.bat exists.Also, I get a blank list of configured CAD Workers (in the "Current CAD Worker Configuration" list) when I click the “CAD” option in the Graphics Server Admin page (nothing is listed in the “Current CAD Worker Configuration”) . If I click “Configure” button in the "Current CAD Worker Configuration" dialog, it walks me through the process of specifying the Host, Data-Type, Where the EDS is running, the Execute command (I specify the full path of the proeworker.bat file in the setup directory that was created during the proe2pv_config). And when I’ve gone through all this and click “Finish” at the end, it brings me back to a blank list of configured CAD Workers (in the "Current CAD Worker Configuration" list), still without anything in there to select.Thanks,Emmanuel AnkutseThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
