Proe_borrow.bat? License borrowing for Creo 2.0
PrashantChandan
2-Explorer
I have installed Creo 2.0 any idea how to borrow license? I had creo/elements was able to borrow license from server.
I am unable to locate same batch file to borrow license from server. Does it depend on license?
Your feedback will be helpful.
Prashant Chandanapurkar
When you get a new license file from PTC, they send 2 files. One is borrow enabled, the other is not. Be sure you have installed the file that has the BORROW parameter in each license key field.
I don't have CREO 2 loaded, but in Wildfire and CREO 1, look for ptcborrow.bat.
Thank you,
Ben H. Loosli
USEC, INC.
It's in the <loadpoint>\Creo 2.0\Parametric\bin\ptcborrow.bat
David Haigh
