I was able to login in PTC Creo element direct modelling 6.0 successfully till day before yesterday, but while login in today I am getting a proxy configuration message. Also i am having good internet connectivity and have also tried requesting manual activation but web-page shows that it is under maintenance.
As i was unable to find an solution to this error in any other related topic, so i had to re-create this topic.
Best Regards,
Anandraj Jadhav
I just tried logging in today as well. I also come across the same issue. It appears that Creo support servers are down. Does anyone know how long it will be to bring these back on line?
The problem is solved, i am able to login in successfully in Creo elements.
Anand
