Purge for non-administrators...
pdkoren
7-Bedrock
Anyone have a purge executable/program that doesn't require Administative Privelidges to run on a Windows 7, 64bit system? I seem to recall being able to run TrueUtilities this way in a "past life" but all I can find in my files is an installation .exe for it. I wonder if I installed it at home, and then just copied the files to my work system, if it would run, even somewhat crudely. I don't have much purging to do, we pretty much run everything in Windchill, but occasionally, I have cases were I work "offline". I do have the option to get our tech support involved, just looking for an easier, quicker more self reliant way thru this.
thanks in advance...
bgruman
(To:pdkoren)
Paul, I think this should work for you.
Also, I need to give credit to someone else for this, but I'm not sure
who... I know this idea came from someone on this exploder, then I took
that idea, modified the commands a little bit and here is where it ended up
for me... So, Thank you to whoever started this...
1) Create a file with "notepad" called "CREO-Purge.bat" (or something like
that) and place it somewhere on your C: drive.
2) Copy the following lines (between the dash lines) into your new .bat
file:
