Hi all
i would like to know how to purge working directry so that the size doesnot grow unneccesarily.While i have selected working directry and when i give purge command in cmd it gives error.the image of the error is attached.kindly help.
Hi David,
here >> http://communities.ptc.com/message/201439#201439
you can find a lot of information about Purge command ![]()
You need to add the Creo BIN path to your system path (environment variables)
(...c:\etc...)\Creo 2.0\Parametric\bin
Hi David,
but the black windows flashes and then disapperas.is there any another problem?
you can create custom mapkey for purge.
Here is the video for you: http://www.youtube.com/watch?v=RHLXsWtPojc
... and/or, here is the purge makpey "pu" *(copy to your config.pro file):
mapkey pu @MAPKEY_NAMEPurge command;@MAPKEY_LABELPurge;@SYSTEMpurge;
thanks. it works now.
