I received a few responses on this. I need to clarify this is not for
sheet metal parts per se. These are parts cut from plate stock up to 1"
thick. Until we acquire Pro/NC Sheet Metal we need to generate dxf files
from Pro/E drawings to feed the laser cutting machine.
Basically it was suggested that I force the dxf output to be 1:1 scale
by setting the "dxf_out_scale_views" config option to "yes". This will
ensure that geometry exported to dxf format is 1:1.
Thanks to all.
Phil
