After downloading the application and following the installation and running instructions, Creo is unable to run it in my envionment: our anti-virus system takes down the exe file.
Consequently I'm sorry to inform that i'll be of no support on this topic.
You need to use Creo in Italian Language.
As there can be multiple possibilities to your question, there is a need to clarify where you are at right now.
Do you mean that you installed Creo and the menus are in English and that you need them in Italian?
I work in Italy the program and the menus are in the italian language.
The program open_drawing_cr2.exe for open drw from part not work with italian language, but only with english.
Dear @Daniel82
Creo in Italian is installed correctly and you run a program called open_drawing_cr2.exe.
This is the first i hear about this program.
Can you tell me what it is ? and who supplied you with it?
you Can find it at this link
Is there a button to quickly open the drawing for an on-screen model/assembly ?
is the old discussion in this site
Right Martin Hanak says he created the application and his first post is rather straightforward: it is works in English Creo.
I'll leave it to @MartinHanak to address this topic.
OK I read that the program works in English, I would like to know if another person can help me to make it work with the Italian language
