Re: Creo 2.0 - Open a drawing from active part?
Daniel82
8-Gravel
Hi
How I can  use the program with Creo in Italian Language?
remy
(To:Daniel82)
After downloading the application and following the installation and running instructions, Creo is unable to run it in my envionment: our anti-virus system takes down the exe file.
Consequently I'm sorry to inform that i'll be of no support on this topic.
7 REPLIES 7
remy
(To:Daniel82)
You need to use Creo in Italian Language.
As there can be multiple possibilities to your question, there is a need to clarify where you are at right now.
Do you mean that you installed Creo and the menus are in English and that you need them in Italian?
Daniel82
8-Gravel
(To:remy)
I work in Italy the program and the menus are in the italian language.
The program open_drawing_cr2.exe for open drw from part not work with italian language, but only with english.
remy
(To:Daniel82)
Dear @Daniel82
Creo in Italian is installed correctly and you run a program called open_drawing_cr2.exe.
This is the first i hear about this program.
Can you tell me what it is ? and who supplied you with it?
Daniel82
8-Gravel
(To:remy)
you Can find it at this link
Is there a button to quickly open the drawing for an on-screen model/assembly ?
is the old discussion in this site
remy
(To:Daniel82)
Right Martin Hanak says he created the application and his first post is rather straightforward: it is works in English Creo.
I'll leave it to @MartinHanak to address this topic.
Daniel82
8-Gravel
(To:remy)
OK I read that the program works in English, I would like to know if another person can help me to make it work with the Italian language
remy
(To:Daniel82)
