Re: Version (Revision + Iteration) on drawing?
seanmcdonn
as per this thread similar issue
What is the parameter used to display revision and iteration in one field on the drawing?
StephenW
(To:seanmcdonn)
&PTC_WM_VERSION:D
The ":D" on the end is the the drawing version
Don't use the ":D" for the current model version
BenLoosli
(To:seanmcdonn)
Look in Tools-Parameters of your drawing file to get the Windchill parameter names. Using the name with the ':D' on the end will pull the parameter from the drawing. Using :MDL will pull the parameter from the active model on that sheet.
