I'm using a remote desktop connection for the following user appears for me The error "(-103) Cannot checkout an uncounted license within a windows terminal services guest session" or "Terminal Server Remote Client Not Allowed" is received while launching application like Creo .
There would be a way to solve this problem the license and Creo Design Essentials - Locked
YES, floating license will work via remote desktop connection.
locked license cannot be used via remote desktop connection. I hope Teamviewer enables you to use locked license remotely.
Hi
More outside Teamviewer would have another way with another type of license?
@MS_Santos wrote:
Hi
I am sorry I do not understand your question.
Hi
Today I use Creo Design Essentials - Locked if I put another license will a floating one work?
Hey Thank you very much I will exchange for a floating .
