Retrieving a detail symbol definition SUMMARY
Highlighted
Gravel
Thanks to Mike Fussy for helping me out. The function
ProDrawingSystemDtlsymdefRetrieve does not use the pro_symbol_dir config
option as the documentation says. Therefore you need to use
ProDrawingDtlsymdefRetrieve passing the path returned by ProConfigoptGet
with pro_symbol_dir as the first parameter. Also, the name of the
symbol CANNOT contain the .sym file extension.
ProName pro_wszConfigOpt = L"pro_symbol_dir";
//Get the pro_symbol_dir config option
pro_error = ProConfigoptGet(pro_wszConfigOpt, pro_wszSymbolPath);
//Retrieve the symbol definition
pro_error = ProDrawingDtlsymdefRetrieve(drawing, pro_wszSymbolPath,
L"scallop", PRO_VALUE_UNUSED, PRO_B_TRUE, &pro_dtlSymDef);
Patrick Williams | Sr. Application Engineer | Engineering Systems |
Steelcase Inc. | 616.698.4078
