Running CREO 3 and 4 on windows 10
zoser
I can not run the Creo 3 and 4 on Windows 10. Could someone help me to solve this problem?
MartinHanak
(To:zoser)
startup problems are usually related to:
1.] graphic card drivers
-OR-
2.] virtual network cards
Case 1.]
Open CREO3_LOADPOINT\Creo 3.0\Mxxx\Common Files\text\config.pro file in Wordpad and add following option at the end of the file:
graphics  win32_gdi
Then try launching Creo.
Case 2.]
Goto C:\ProgramData\PTC\Licensing directory. This directory is used as location for saving license file. Upload licence files to your reply - I will check the contents of them.
Open DOS prompt window and run following command:
ipconfig /all > ip.txt
Upload ip.txt file to your reply - I will check the contents of it.
Also upload CREO3_LOADPOINT\Creo 3.0\Mxxx\Parametric\bin\parametric.pf file - I will check the contents of it.
Martin Hanák
5 REPLIES 5
MartinHanak
(To:zoser)
you have to provide as much details as you can, if you want to get help 🙂
Martin Hanák
zoser
(To:MartinHanak)
- I am trying to run Creo PArametric and Creo Simulate 3 and 4
- all are Student versions
- Yes, the Software are installed
- I'm not connected to a PDM system
MartinHanak
(To:zoser)
-OR-
Case 1.]
graphics  win32_gdi
Case 2.]
Martin Hanák
BenLoosli
(To:zoser)
What builds are you trying to run on Windows 10?
Student or Production versions?
Does the software install?
Are you connected to a PDM system?
What happens when you try to start them?
zoser
(To:BenLoosli)
- Student versions
- NO, I'm not connected
- It seems that the program is to start, then nothing
