Running Creo on MacOS via Parallels
ZM_10242308
7-Bedrock
Good day,
I am encountering a customer if we can run Creo Parametric 10.0 on MacOS via Parallels (similar with bootcamp emulator of MAC to make it windows OS) . We know that Creo has no version for MacOS but once Parallels was used will be there an issue or problem with it still? Let me know also if there is a article case of creo connected with Parallels. Thank you.
2 REPLIES 2
Hii, Thanks for your response. This is helpful for the additional documentation that I can use to justify to the customer that Creo doesn't support MacOS even by Parallels emulator.
