Running a mapkey on startup
gkling
Is there a command for the config.pro to run a mapkey on Creo startup?  If so what is the syntax?
Thanks, Greg
1 REPLY 1
bgruman
(To:gkling)
Greg,
Not sure there is a way to run a Mapkey on startup,  but you can call a trail file on startup that then runs a mapkey...
I created a bat file and use that to startup Creo...
Below are a couple lines pasted directly from my Bat file.  (obviously, I'm still on Creo2)
set path=C:\PTC\Creo2_M130\"Creo 2.0"\Parametric\bin;%path%
CMD /C C:\PTC\Creo2_M130\"Creo 2.0"\Parametric\bin\Creo2_M130.bat J:\PTC_Client\Start_Trails\Creo2\start_Creo2.txt
Good Luck
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
