Running analysis as a scheduled task
egifford
3-Visitor
I have a user that is trying to launch a mechanica analysis batch file
using a scheduled task and it isn't working. Double clicking on the .bat
file works (command prompt window pops up, the software starts and the
analysis starts running). However, when we attempt to run that same .bat
file using a Windows scheduled task, the command prompt window just pops
up and disappears - the analysis never runs. Is there something that
needs to be added to the batch file or a setting in the scheduled task
that needs to be added / specified?
Erik Gifford
G.W. Lisk Co., Inc.
OS: Windows 2000 SP4
ProEngineer 2001 build 2004090
Mechanica 2001 datecode 2001430
Just check once for the "start in directory" in scheduler.
Is it the same directory (where .bat file is kept)?
If no, then change it to the same directory.
Anit
