Hi IS_10317526
Regarding such wrong behavior on some machines only, please review article CS352473 - Unable to modify dimension with a Double click in Sketcher when using Chromium as embedded browser in Creo Parametric
Hope this will help
BR
Jean-Claude
Hi IS_10317526
Hope this will help
BR
Jean-Claude
Hi IS_10317526,
You can also refer Article - CS352944 - Unable to select modifying Sketcher dimension in Creo Parametric 7.0.5.0 (ptc.com).
Regards
Ray
Did someone lock the dimensions?
