Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
It seems I need to retract my earlier statement that "this config setting does not seem to be a good choice in conjunction with Intralink."
The issue I was having stems from family tables.
Let me start from the beginning. Several users instructed me to simply move my relation POUNDS = PRO_MP_MASS to the "Post Regeneration" section of the Relations, and use the above config options, and that would solve all my problems. I had tested this, and found that this resulted in oodles of modified parts. I was advised, "It'll only happen once - check those parts in and they'll never be modified again after subsequent mass prop calculations." I tested this, and found it to be untrue - I was STILL getting oodles of modified parts. That's when I made the statement above.
HOWEVER, I've further tested it, and discovered that the issue stems from Family Tables. Specifically, I needed to add the POUNDS parameter to the family table for any part which uses the POUNDS = PRO_MP_MASS relation. Once I did that, it appears to fix the issue.
Thanks to all that helped (and that prompted me to keep investigating!)
Lyle Beidler MGS Inc 178 Muddy Creek Church Rd Denver PA 17517 717-336-7528 Fax 717-336-0514 <">mailto:-> - <">http://www.mgsincorporated.com> This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
