SYSTEM RELATED PROBLEM
ptc-5763954
MY SYSTEM CONFIGURATION IS INTEL CORE2 DUO CPU P8400 @ 2.26GHz 2.27GHz
RAM 3.0 GB
WINDOW 8 PRO(32-BIT OPERATING SYSTEM)
CREO 5.0 IS VERY RUNNING SLOW ON MY SYSTEM.PLEASE TELL ME THE SOLUTION?????
THANK YOU
Please once have a look on software & hardware compatibility matrices for CREO, it will help you to choose system configuration....
9 REPLIES 9
upgrade your pc to 64 bit and add some memory may be 4 gb/b gb ram with 1/2 gb graphics card.
It looks like you use old age computer. The processor was launched in 2008. Its performance is poor when compared with current processors. See http://www.cpubenchmark.net/cpu.php?cpu=Intel+Core2+Duo+P8400+%40+2.26GHz
I think it does not make any sense to upgrade the computer ...
Martin Hanak
Martin Hanák
Here is the page Sandip is referring to.
http://www.ptc.com/WCMS/files/77552/en/proewf5.pdf
try to upgrade to latest graphic drivers for windows 8.
is your hardware compatible with windows 8?
i think windows xp would be the solution to your problem.
well everything is ok to me.i'd suggest just make sure you got a good graphics card,my recommendation is nvidia gt 610,you won't face any problem.
Creo 5 ????
Creo Elements/Pro 5.0 (Pro/E Wildfire 5.0) probably.
Right
