I have a tree.cfg file that I want to automatically open whenever I launch the academic version Creo Parametric 2.0. Can someone please tell me how to do this?
If you launch creo from an icon in windows, right click the icon and choose properties. In the properties window change the "start in" to your desired directory.
Place it in your launch directory and/or modify the config.pro option mdl_tree_cfg_file with the path to your tree.cfg file. Reply back if you need more detailed instructions.
I just figured it out. I was putting the config.pro file in the wrong place. Do you know how to change the launch directory?
Thank you very much. This has been very helpful!!
You're welcome!
