Hi Schematics Community!
We are launching a WHDP project and configuring Schematics and Parametric for the first time and will be a frequent contributor from here on out! Yay!
So I"m a Creo Paramteric admin guy and wishing I had a config option to set the default Location.
Is there such a way to acheive this?
Hi ,
Default location for designs can be set by:
for additional info, please review topic :"About Creo Schematics System Default Files" in Creo Schematics Help Center
(if directories defaults were not set - the defaults will be the start folder as defined in the application shortcut properties)
Gaby.
Hi ,
Gaby.
You can set all your Directory Defaults, Switches, Folder Structure on local machine, and push latest Configs, such as UI's, Plot Files, ...ect to all your End Users with a .bat file. and a start-up shortcut referencing the .bat file.
John
